It gives you more info to put in your signature for the forums?Can’t believe people still buy these.
Yeah, a throttle booster only changes the input ramp from your pedal. So when you're giving a 10% push, the computer thinks you're giving 13% or 7, or whatever you have it set for. I use it so I don't give too much input out in the mountains. Also, don't spend $350 on a pedal commander when a $150 hikeit does the same thing.I am not here to bash on your opinion. I have never tried one of these but have heard both sides.
Question for you, I see in your signature that you have an 87mm TB. What size is this? Does it reduce back down from the 87? I (once again "have heard") that bumping up the TB size can create a lag. I wondered if this necked back down to negate the 87mm TB, taking the lag out. Just a thought. It makes me wonder if you would feel the same bump with the stock TB.
Hey, responsiveness and feel account for a lot. Many people dish out for Pedal Monster or similar add on and swear by them. They don't show a difference on a dyno either, just responsive feel.
So you put a bigger throttle body on, and then basically negated any performance increase from better flow of the bigger throttle body by I staking a spacer that removes said extra flow. Of course your throttle response changed because you increased your vaccum signal in the intake by throwing the spacer in that is smaller than your TB. SOTP makes you "feel" that its quicker, but Dyno numbers and track times sound say otherwiseI upgraded to a 87mm, I guess the spacer is 85mm
That was the only question I had when ordering it. I liked the bigger throttle body, didn’t really feel a lag, but it opened up the engine a lot.
the opinions are all over the place so I decided to try it myself. I can see it not showing much a difference if your all stock.
You should remove your ported throttle body and sell it since throwing this spacer on cancels out the throttle bodyI got it for 30 bucket off of fb marketjust like the whistle noise that's all haha I wasn't really expecting much
You know... thats actually a good point LOL i didnt even think of thatYou should remove your ported throttle body and sell it since throwing this spacer on cancels out the throttle body
