jwilliams
I had a mechanic install the 5100's and he put the circlip in the wrong spot(Instead of 1 slot from the top, he put it 1 slot from the bottom). Question for any mechanics out there, Can you compress the spring while it is in place to adjust the circlip? Or do I have to remove the entire strut unit again. Looking at it, I would guess I have 2"+ of compression in that spring.
The mechanic was a friend doing me a favor, so I want to see if there is a easier way to adjust the height.
What do you think?
What do you think?
