M
Mdegen93
Guest
Where is everyone putting aftermarket switches for accessories like light bars etc
Yeah that’s what I was thinking tooI have rear strobes installed on my Magnum headache rack and put the switch for those just to the side of the pull handle for opening the hood. Not the most ideal for a light bar, but it's hidden. You could mount it to the side of the center console just above where your knee goes, that would make for easy access.
I think it would be cool if you don’t have parking sensors and air suspension, then use the lever there as the light switch.
It's not possible currently. Those switches are all integrated into a single module that outputs a signal through an 8 pin connection.I was thinking the same thing! I don't have air and would like to have a light bar switch where the air should be. has anybody done this or know how to?
I don’t know if anyone has done this. But if it’s achievable then it will be so cool haha. However, I think first you need to order an OEM lever or the whole lever system. I also see a Demon owner 3D printed a set of switch, which also looks pretty cool and customizable. Sorry about my English if I made any mistake.I was thinking the same thing! I don't have air and would like to have a light bar switch where the air should be. has anybody done this or know how to?
You sir are a life saver.I went with one of these for my future lights.
https://www.speedtechlights.com/Switch-box-control-panels/wireless-remote-control-switch-box
Only wire I will have to run is for my electronic air horn.
https://www.speedtechlights.com/police-sirens/pa-100-watt-public-address-air-horn-system
How is the wireless switch working out for you?I went with one of these for my future lights.
Post up...I'm planning my lighting setup but can't solidify anything until I get the truck in and get some measurementsGood so far. Use it for my volunteer firefighter lights and my Rigid off road light.
