CJ8Ranger
I tried to get the answer to these questions from another thread on the cargo divider, but I honestly came away more confused, as I couldn't tell the difference between silver and black rails, as the rails come in both colors.
I have a 2023 Limited Ram 1500. No MFT and no RamBox. It has the OEM Ram Trifold soft cover. I am looking to add a cargo divider. I have found one which is made by Roll and Lock, but I think Mopar makes the same part.
1. Does anyone know if this cargo divider comes with the pictured rails?
2. Do the rails from the BUG, 82215285AB, have to be ordered to fit with this divider?
3. Can the two be used together?
4. Do the two need to be used together?
5. Are there any fitment problems with the OEM trifold soft top?
6. Does anyone know if using both of these items will interfere with the use of a retractable tonneau cover like the Retrax or the Roll and Lock?
Thanks in advance and apologies if this has been covered elsewhere.
82215481 MOPAR RAM 1500 DT 5TH GEN CARGO BED DIVIDER WITH HARDWARE 2019-2023 OEM - MOPAR (82215481)
This divider shows black rails that come with the gate, however it says it needs the "pickup box utility Rails." I think the "pickup box utility rails" are the OEM rails that come with the Bed Utility Group.2019-2023 RAM 1500 DT 5TH GEN PICKUP BOX UTILITY RAILS FOR 5-FT 7-INCH CONVENTIONAL BED OEM - MOPAR (82215285AB)
