This had been addressed many times for the Alpine (and HK).
I used the search feature at the top of the page, "Amplifier" and here is what I have for starters:
BTW - welcome to the forums ...
What’s everyone’s best recommendation for using a plug and play processor to wire aftermarket amps. I’m looking at the Rockford dsp1 and axxess am dsp. Has anyone used either? Or is there better out there. I’ve used the lc7i in the past but don’t want to cut any wires
5thgenrams.com
Hello, Just looking for some advice on Amp selection. I just ordered the Fox Acoustics Box (Sealed with 2, 10” Subs), and planning on buying 2 JL Audio 10W1v3’s 2 ohm Subwoofers. Would either of these 2 have enough power to adequately push these speakers in a sealed box? Alpine MRV-M500 Mono...
5thgenrams.com
I'm going to start my thread on installing my aftermarket subwoofers. As I go with the install I'll be uploading more pictures. My equipment so far is: 2 Sundown Sa10d4 Orion xtr 2500 watt amplifier Pac amp pro-to get the signal Custom subwoofer box(ported at 2.06cuft)-still no carpet going to...
5thgenrams.com
Amp is behind the rear seats .. others have posted photos in their particular upgrade posts.
There is plenty of suggested links as well.
If you are reading this, scroll down and you will see even more links that you can browse
