Adding an amp and sub to 2025 HK system
Largefarrva
5thGenRams Supporter
I have the HK system in my ‘25 Laramie and while it sounds decent the bass is underwhelming at the lower frequencies. So I would like to add a Sundown 8” sub and SALT 1 or 1.5 amp to power it. I plan on using the stock sub and speakers powered off of the stock amp.
What power and other considerations will I need to take into account to do this? I’ve read that there is some sort of bypass for the ANC…can anyone point me in the right direction for that?
Also, can the alternator handle adding a 1000 watt sub or am I looking at having my to add an AGM battery to do this?
Anyone else with experience care to comment on the power requirements part of my question?
That guy linked above at NetAudio, will have all your answers, for sure.......................
I have HK system in my '19 Longhorn, and plan on adding amp/sub. I have the amp already, and a decent 10" sub. I need a box, still undecided on ported or sealed. I bought (and installed) the ANC bypass cable from NetAudio, and will likely buy a custom box from him at some point.
I sent him an email asking about this and no reply. Guess he might not want to give out advice? Dunno.
So hopefully someone here can chime in.
I've corresponded with him a few times, he's always a bit slow. If you watch some of his videos on YouTube, you can see he's plenty busy and knowledgeable... and ... a lot of his installs are on RAM's.
If you have Facebook, try messing there. There is also a 5Th Gen Audio Page on FB that he's part of.
21 Ram 1500 bighorn 4x4 not e-tq base audio, I installed a kicker key 200.4, but same question as original poster, would around 1200 watts be too much and cause headlights to constantly flickering etc. I want the dual 10 fox box, but how long after ordering do they ship out normally by others past experiences.
Neither of you will have any power issues using the stock alternator and battery. I’m running almost 5k watts on stock 220 amp alternator in my grand Cherokee. Class D amps are easier on electrical systems.
