"ADD design"..."REBEL"
Always amazed at how small the world is when you can watch someone in Bahrain wrench on the same truck you have in near real-time...
the ADD front bumper looks good, not a huge fan of the rear's angular cuts from the rear view
*Edit* this guy's Ram has air suspension, so i'd be curious to follow along and see what 4
lift he's talking about using
Here is the after pic...not sure I like it...too small. For off road I get it, but for looks...
It's amazing what these guys can do overseas. My 2010 Tundra best dyno run was 411 at the rear wheels with the factory TRD supercharger. They re-flash the computer once installed, but it still has it limits that the factory puts on it. They bump up speed limiter to 125, best run at the track was 13.3. These guys overseas warranties are gone usually once it is shipped to them. They have learned to tune them very well and have saw speeds on the Tundra well above that in Saudi. I will be watching his channel to see what else they can get out of the Ram. His next video was the header/exhaust install and showed no gain really on the dyno. I'm curious to see if they start trying to set up some tunes that they build on it for performance that will probably never be accessible to us or throw a supercharger on it. Of course cost is usually not an issue either. They love their performance cars.
link to video, hope it works---
tried to add link to video but did not work.
I looked it up on youtube and put the following in to find it "EVERY TRUCK NEEDS THIS"
scrolled down a bit and found it.
I just pressed video and then got black screen with link to open YouTube which worked fine.
I like the idea but too skinny and I’m not keen on the sharp angles, doesn’t look right with the trucks curved corners. All the after market ones I’ve seen are too square/sharp looking for my taste but world would be boring if we all liked the same :)
I imagine they’d be better off road for those that do a lot of that.
