DenverDoesIt!
- Aug 22, 2023
I have a 5th Gen 2019 Ram 1500 Big Horn. I have a engine light on my dash. Went to the local parts store and it showed a code related to AGS. So I researched some things on YouTube and pulled my grill off thinking I would just Delete it from the truck. Finding out that there is no bracket that can be purchased to delete like previous generations. I removed the whole AGS assembly, moved the shutters closed with my hands. Then plugged it back in...the shutters opened. They do not close at least sitting in driveway that I can tell.
1) So it appears that perhaps the shutters may be working (at least in one direction from close to open. How can I tell if the AGS is working like it should be..to get it to open and close?
2) If there is an issue and code is correct, how do I Delete this option on 5th Gen Truck? Or do I need to buy a new assembly?
3) Any other advice/knowledge on what may be causing this AGS code if not addresses above.
Thanks in advance.
Thanks in advance.
