duracell24
- Jun 25, 2019
Need some wisdom. Here's what I did...
1. I removed the static front Air Dam with the 15+ screws that held it on.
2. I removed the ENTIRE Active Air Dam (AAD) system including the motor. Zip tied the open plug onto the frame and taped it.
--Truck ran fine for a week. Then got a CEL. Took to dealership. Said it was due to truck sensing there was no AAD motor attached.
3. Added back the ENTIRE AAD system including the motor. Got smart and removed only the actual plastic dam piece. Left the motor and long, silver rod that runs across in place. In my mind this would fix the issue since the motor was now connected.
--CEL remained on for 2 days then disappeared. I figured this was problem solved as the system finally recognized the AAD motor was back.
--After 24 hours of no CEL, it returned this evening!!
Why would it return? The AAD motor is plugged back in. I reverified tonight that it's securely attached. The AAD system is in place minus the long, plastic dam piece that I removed with 4 screws.
Could I have reinstalled it incorrectly? Has anyone else had this issue? Is there some kind of delete kit I can buy to plug into the plug instead of the motor?
In the pics, the yellow circles the plug so you can see it's reconnected. Thanks in advance for any help!
