Active Air Dam has been posing problems.
Neadspeed243
Hi all,
Background:
-1 year ago I removed the Active Air Dam and did not tape up the connection under the truck
-6 months later, when my battery died a CEL came for the active air dam & active grill shutter.
Tried reinstalling the active air dam and did the following:
- Took to dealership to clear it
-Disconnected battery and let it sit
CEL hasn’t gone away in over 6 months now.
Just today, I got my security bypass cable, AlfaOBD, & OBD connector.
I performed the following steps to clear it;
-Car Configuration -> Active Air Dam -> switched from Yes to No.
-Cleared the code
-Changed the mode to engine so it’s not just the PCM but also ECM & cleared the codes as well.
It went away, only to come back later.
I did the same thing again after I removed the active air dam now and I’m having the same output with it throwing codes and the check engine light coming back on.
I bought all the AlfaOBD stuff & a smartphone just for this to clear this check engine light, wasted like $250 so far on just this.
I just want my check engine light gone and my ability to start my truck from my key fob without it shutting off seconds later again.
What else can I do?? I really would appreciate any advice.
Quick question, are you sure it’s not your active grill shutters setting the code?
