bryanb1982
- Oct 6, 2022
My 2022 Ram 1500 Bighorn 4x4 came with the Active Air Dam. I replaced my bumper with a higher clearance once and a skid plate. The Active Air Dam wouldn’t fit, so I removed it. I did not detach the motor from the dam and leave it attached. I removed the entire assembly.
I don’t have a visible check engine light, but I do have malfunction codes related to it. Also I noticed that my horn chirps on unlock now instead of just lock.
I also get weekly notices from the dealer that I have a malfunction indicator.
I pulled my logs through AlfaOBD and see Active Air Dam as Yes. I was under the assumption that if AlfaOBD reported it, I could manage it. However I can’t seem to find the option to set AAD to false. I can’t even find AAD. Only thing I can find is a test for the Active Grill Shutters.
Does anybody have an idea what menu path I would take to find this? I looked through every menu and didn’t find anything that just jumps out as AAD.
Any help would be appreciated. I could care less about the malfunction indicator. But this extra chirp is driving me nuts. I don’t want to lose the one on lock, but this one on unlock needs to go.
