award3
- Mar 5, 2021
I have a 2020 ram 1500 bighorn with halogen headlights. I recently purchased the Acanii black headlight housings that match OEM. When I plug in the factory truck harness into the aftermarket headlight it doesn't seem to fit right. The pin layout is the same on both ends, but it looks like the pins aren't long enough on the Acanii headlights to fully insert into the factory harness. The lights will sorta flicker a bit as if the connection isn't fully inserted. Anyone have this issue?
