AC outlet not working
KCURTMAR91
Hello Fellow Ram 5th Gen owners,
I just bought a used 2019 BigHorn which has a AC outlet but it does not seem to work (did not check that before purchase :( ). Does anyone know where the fuse is for this? It must have an inverter somewhere, where is that located?
CMil527
Old Bridge, NJ
Welcome... not sure on the fuse, you looking for the one on top of the dash?
Rick3478
NW OH
1) These will only put out a few hundred watts and 2) I think the ground prong hole actuates a micro switch that turns on the inverter. So what did you try to plug into it?
KCURTMAR91
Thanks everyone for the info - fixed (was blown fuse) and working. NOTE: it works with out a ground plug (so the ground prong hole does NOT actuate a micro switch)
Eighty
Moderator / Dream Killer
Should be:
F35 – 10 Amp Red - Mod Inverter / Mtr Sunshade Sunroof / Mtr Dual Sunroof / USB Charge Only
Edit: Or F60 - 50 Amp Red - Mod Inverter
In the Internal PDC
