Ac blowing only from the defrost in all modes
talys.raphael
I have a 2021 ram 1500 5th gen laramie, and the a/c is only blowing in defrost mode, if i select the floor, it blows air on the floor for a second and instantly goes back to defrost.
I believe the problem is in the blend door actuator, I bought one to replace it, but I couldn't find where the part is located.
Does anyone have a diagram of where the blend door actuator is located?
thanks!
Try Youtube. I didn't look for it, but generally everything is on there. Or if you have the part, just search the part number. That generally brings up exploded views of the part.
Buried pretty deep in the dash as far as I can tell, you will have your work cut out for you.
AlldataDIY has all the info if you don't mind paying.
