This is correct...it's not A/C, it's a ventilating fan under the seat. And I find my ventilated seats are too cold when the cabin is cooled down a bit, so I turn it off after just a few minutes.The seats sucks air in, not out. So if your cabin is hot, you won't feel the cooling effect until the A/C has cooled down the inside cabin.
Too cold? That's funny. Come to Arizona where nothing is too cold.This is correct...it's not A/C, it's a ventilating fan under the seat. And I find my ventilated seats are too cold when the cabin is cooled down a bit, so I turn it off after just a few minutes.
In Michigan they never feel cold. They barely stop you from sweating.Too cold? That's funny. Come to Arizona where nothing is too cold.
Yes, that's exactly how they work.Interesting but it still doesn’t feel like they do much ? I imagine they suck air in through the small perforated holes in the seat ?
They actually suck air, not blow it.They’re not A/C seats, they’re vented seats.
they have a blower that blows cabin air up your butt and lower back. There’s no separate A/C or vents for the seats.
the “heated” part uses electric coils to warm the seats.
It's great for hot fartsThey actually suck air, not blow it.
I wish our brains came with an "unsee/unread" function.It's great for hot farts
Actually that's incorrect. The fans blow up into the underside of the seat and up into the backrest. They do not draw down through the holes - it wouldn't work when your *** is in the seat blocking the holes. I was curious and checked to find it blows up into the seat.Yes, that's exactly how they work.
I guess the effect varies for different people. I don't even use the Hi setting as it cools too much - I usually use Lo.In Michigan they never feel cold. They barely stop you from sweating.
I'm on my third vehicle with them, and none of them made any difference. Maybe because I'm a big guy, and cover all the holes. But even just holding my hand against the seat, I barely feel anything.I guess the effect varies for different people. I don't even use the Hi setting as it cools too much - I usually use Lo.
No, sorry. You're mistaken. They pull air in through the perforations in the seat bottom and back. Don't believe me? Turn them on and set a piece of paper on the seat back. It will be pulled against the seat surface.Actually that's incorrect. The fans blow up into the underside of the seat and up into the backrest. They do not draw down through the holes - it wouldn't work when your *** is in the seat blocking the holes. I was curious and checked to find it blows up into the seat.
Turns out we're both right. The seat does draw air in through the perforations when you're not seated. I'm average build, but even so my butt and thighs cover about 95% of the perforations blocking air flow. Same for the backrest. Logically this wouldn't work for cooling if that's all it did. Putting your hand on various parts of the seat, you can feel it being cooled away from the perforations even when blocked, so I figured something else is going on.No, sorry. You're mistaken. They pull air in through the perforations in the seat bottom and back. Don't believe me? Turn them on and set a piece of paper on the seat back. It will be pulled against the seat surface.
That's great info. Explains why I never felt anything. I said I didn't think they did much, due to the fact I felt no air. Never thought about surface temperature, assuming the perfs were supposed to cool while driving.Turns out we're both right. The seat does draw air in through the perforations when you're not seated. I'm average build, but even so my butt and thighs cover about 95% of the perforations blocking air flow. Same for the backrest. Logically this wouldn't work for cooling if that's all it did. Putting your hand on various parts of the seat, you can feel it being cooled away from the perforations even when blocked, so I figured something else is going on.
Turns out the seats have two paths to cool them. To cool the seat when you're not sitting there, it draws air in through the perforations to quickly cool like remote start situations so the surface gets cooled if they've been sitting in the hot sun, ready for you to get in. But at the same time, air is also draw up from below the seat and blown into duct "bags" (that's the name of the part) to spread out and circulate the cool air inside the seat to cool the entire seating area. This is how it maintains cool air flow when you're blocking the perforations. The backrest has it's own fan and duct "bag" to circulate cool air too. The seat foam has perforations and channels in it to flow air as well.
It's a simple design really, but it works well to cool the seats. It was well over 100f some days back in July inside the truck in full sun at work, yet my seat was nicely cooled by the time I walked across the lot to get in. See pic below. Parts 12 and 23 are the "bags" that duct the air.
