A/C in Auto?
Bigbags85
WNY
Does anyone know if the A/C runs when the system is set to auto and heat is blowing? If you try and enable A/C it disables auto.
Scap
Typically, the compressor will run in defrost mode. Not sure about other heating modes
Bigbags85
WNY
Okay, I was curious about the RAM because I know in my other car I can have the option to keep it on to help dehumidify and keep windows from fogging. I haven't really noticed any of the front windows fogging up but the rears do.
Threesuns1
Northeastern Maryland
Auto will try to keep the temperature at what you have set, set it and forget it type of thing. The auto setting will determine if AC or heat is call for. An example would be if you a colder temp area and the heat is blowing and you travel south into a warmer area the AC will kick in if the cab temp goes above your set temp, not sure what the offset is. If you press the AC button you are taking it out of auto.
Bigbags85
WNY
I guess that would be a no then, kind of a shame they didn't allow both to be enabled.
Liquid Li0n
Belgium
that is why I sometimes smell the AC when I turn it on myself (by pushing the ac button myself) as I leave the climate setting always in auto. But they say to use the ac from time to time, also in winter, cause otherwise mold comes on the filter.
Also AC is not only for blowing cold wind, but also makes the air dryer, which is interesting in moist/high humidity conditions in these winter times.
