ericcloe
- Jun 8, 2021
Can anyone let me know all the settings for the 8.4 with nav. I have swapped the unit from my 5" that has Sirius. All seems to be working besides the volume knob and tube knob and the auto climate control knobs. Also the backup camera is still blue saying unavailable. I can control the temp and stations through the display but can't turn the volume up or down since the knobs are not working. Any assistance would be appreciated in getting this fixed. I do have the splitter between the screen and the temp controls made by Jimmy07. The radio has been in a couple days so not sure if I should have everything working from the switch now or not.
Here are the settings I put in with alfaodb
Choose ram 2500 (DJ/DR)
Choose body computer select body control module my 2019 or 2020.
Choose Car configuration change. Go almost all the way down the list till you come to
Cab Net ICS integrated center stack. Click it and enable it.
Scroll down a couple and click on Cabin Net DCSD display screen module and enable it.
If you cant get AC to work move to next step
Now for hvac controls.
Connect again to body control module go to car configuration then vehicle config 3 HVAC (found only hvac 2 and enabled)
Select value tab : dual zone ATC .
Hit start. And done
Note: sometimes it take a few times driving for sirus radio and back up camera to start working again.
Hit start. And done
