8.4 signal output help
KRField
Tri-Cities, TN
Does the base 8.4 provide a clean flat audio out before or after the ANC module?
Trying to figure out if I need a summing device or if I can go directly to a DSP for amps.
Adrianp89
On the older ones, I believe you get a decent signal from the stereo, however you will need to put load resistors on it if interrupting speaker wires.
