PeteyK49
Hey. I want to upgrade my base 6 speaker system w/anc. I already have the anc bypassed. It’s tapped to for a hi input for my powered sub. After 2 years I want more. I’d like to get a 5 channel amp to power the front and rear speakers as well as a new sub. I have faitalpro 8ohm speakers in the dash already. I’d like to give my dash and door speakers a little power as well as getting a real sub.
What amps are you guys running and how do you wire it up? I’ve read a lot of threads and it’s confusing for my simple mind. If I get the appropriate LOC with 5 channels, do I splice back into my anc bypass for each of the 6 speakers? Or should I just get aftermarket 2ohm 6x9’s, not power them and a mono block amp setup? I see net audio makes an anc bypass with a PAC already wired up for $150.
I’m looking for an easy solution without spending an arm and a leg is possible. I’m just not happy with the volume of my dash and door speakers. I also want more thump… can anyone help out a simple fellow that is handy for the most part? Thanks !
