I'm not a big fan of posting images online, but thought I'd share these results for those interested.
Install took about 3 days with plug changes to 1 degree colder and gap to .32. Also took a day to have it dynoed and tuned on a mustang dyno by a pro tuner shop in SC.
Purchased unlocked ECU and Trinity2 from Diablosport separately. 2022 Ram 1500 has 3.92 LSD.
+150 HP and +150 Ft. lbs. from stock. Dyno shows trans shift as these trucks can't hold a gear through a run. Took about 5 runs to get it dialed in. Stock which I don't have, but the tuner said is typically about 295 HP and 290 Ft lbs. to the wheels. It's a massive difference throughout the power band, but general drivability and mileage has remained similar to stock.
They're expensive units for sure, but the quality and results are well worth it. Most shops quoted me around $3,000-$4,000 for install, but most shade trees can handle it.
Pulling the front apart for intercooler, plugs, injectors and crank pin are the most difficult parts of install.
