5.7 longevity
Denovice
Hey all, been eyeing up a 2011 Ram 2500 on Facebook and like what I see but it has 200k on it. I just wanna hear what you guys know about how long the lifespan of these engines is.
Thanks
834k3r
As the resident Captain Obvious, I say it probably has more to do with how it was maintained and driven than the engine itself. Does the seller have copies of receipts or logs of engine work done on the rig? If so, the seller probably took good care of it.
mikeru82
The Palouse
Engine longevity is directly affected by maintenance. Like Captain Obvious above said, "I say it probably has more to do with how it was maintained and driven than the engine itself". Having said that, 200k is getting up there. Even a well maintained engine will wear out. I'd have a professional mechanic check it out before buying. It's money well spent.
ekaz
All depends on maintenance but I would consider a top end rebuild at least with that mileage....valve springs, seals, lifters, water pump, timing set, oil pump (since you'll be in there), etc.. That said, I've known a few people with more than 200k on a 5.7.
silver billet
I'd avoid all 5.7 hemis built between 2009 and 2014, they have a much higher rate of lifter tick/failure.
Mr.Grid
Merton, WI
A 2009 – 2016 5.7 Hemi w 200k miles is a valve train time bomb imho. 2017 the lifter rollers were redesigned with larger needle bearings.
My 2011 5.7 Hemi went 179k miles to lifter failure towing a 7k# trailer 84K miles. Meticulously maintained.
GKIII
DFW, Texas
Is the body in good shape? Depending on how much it is, it may be worth buying for a rebuild if everything else looks good. As it is I wouldn't trust that valvetrain, but could be worth doing a rebuild on at the right price.
Dulghum
It's all depends on how well it’s been taken care of and what condition it’s in now. Well taken care 5.7’s can last many many more miles than that.
At 200k miles you're probably looking at replacing ... Everything. Engine transmission etc.
