clazer
- Feb 21, 2019
The air suspension is the same for all air ride vehicles, as I understand it. All that changes is whether you have 4 or 5 settings. In your truck, normal is the same ish as an off-road or Rebel in aero mode. Point being, you can raise your truck just as much as anyone else with air using links and Daystar. However, if you want your “normal” as high as a Rebel’s “normal”, you’re going to lose the use of off-road 2 (probably get an error). No biggie.
Now, the front and back of your wheel well- you’re probably going to have to trim to get 37” rubber or negative offset wheels to work.
