lawlavigne
I have the Bilstein 5100's on front and do not have the ORP. Will 35's by 12.5 on 20's fit with no rubbing? My truck is basically raised about 2" in front and riding level.
When you talk about 35x12.50R20 tires you need to know that they are not all the same, for instance a Nitto Terra Grappler is 34.5 tall , where a Toyo Open Country MT is a true 35 maybe a little over 35 so that would mean an additional 1/4” of circumference pushed into the inner fender well which will be huge especially if you were to have your wheel turned in either direction and have some suspension articulationI have the Bilstein 5100's on front and do not have the ORP. Will 35's by 12.5 on 20's fit with no rubbing? My truck is basically raised about 2" in front and riding level.
Yeah I know not all tires hold a true measurement. I'm more interested in the 12.5 honestly.When you talk about 35x12.50R20 tires you need to know that they are not all the same, for instance a Nitto Terra Grappler is 34.5 tall , where a Toyo Open Country MT is a true 35 maybe a little over 35 so that would mean an additional 1/4” of circumference pushed into the inner fender well which will be huge especially if you were to have your wheel turned in either direction and have some suspension articulation
The 12.5 is what I’m referring to, they are differentYeah I know not all tires hold a true measurement. I'm more interested in the 12.5 honestly.
