35s and 2.5 leveling no spacers... need help
kittyjo
Just got it done Friday and realized it’s to close for the uca and tire less than a finger in the gap.. is this doable or spacers a must? And if so how much don’t won’t to get to wide want to keep it tucked under as much as possible. Truck turns fine in any direction in ful lock... Thanks For the help
kittyjo
Are those the stock wheels? If not, what's the offset? It does look really close.
Stock wheels.. ya it’s close , don’t know if I need spacers or not. Which brand is good and what size to keep it mostly tucked under truck?
LaxDfns15
Memphis, TN
I've always been a fan of Bora spacers as they're hub centric. Pricey, but they're worth it. I think the stock wheels have gaps in them to accommodate the wheel studs if you got with 1" spacers.
kittyjo
I hope so lol best place to order them from? Thanks self install or shud I have shop do it?
LaxDfns15
Memphis, TN
When I used them on my last truck I just bought straight from Bora. If you can jack your truck up, take a wheel off, and bolt it back on you can install wheel spacers.
jabara572
Atlanta, GA
Rough country 6x5.5 1/4" spacer (the GM one) will give you some extra clearance, its what i bought to run 285/75r18's, it just sandwiches between the hub and wheel.
