Search the gallery on Custom Offsets. That's how I found out if my wheels/tires would work with my truck. There is bound to be someone that has that wheel/tire size combo. https://www.customwheeloffset.com/?...4dLOWk1MGmj_sRQ8F1B56wwZ2yxSNInxoC64QQAvD_BwEI have a 21 1500 limited with air ride so not interested in leveling. Going from a +19 22” rim to a +12 offset 20” rim will I be able to run the 305/55 tires or should I just go with a 295/55?
I have the same tires also, but his wheels are +12 offset on stock suspension.I have the same tires on my Rebel with no rubbing. Here's a link to it.
https://www.customwheeloffset.com/w...520/2019-ram-1500-fuel-rebel-stock-suspension
I ended up going with the 295/55 20s and the Baja Boss ATs. Glad I did because these tires are quite a bit bigger than the specs say. I measured the width at 12” and due to the huge tread depth they’re actually a 33.2” tire.I have the same tires on my Rebel with no rubbing. Here's a link to it.
