RamRebelSteel
I finally installed a light bar hidden behind the mesh above the skid plate of my Rebel and some LED pods that go mounted on the hood hinges and run up by the A pillar.
I bought some off Amazon just to test waters. Wasn't sure if I was going to like hood pods but I like it a lot! Now doing some research for better pods. Maybe Baja design XL ProAny pics of the hood pods turned off? I'd like to seem some shots of those.
I got them from zroadz. They're pricey for 2 peices of metalSame here, and where did you get the brackets?
Not at the moment. I should have time this weekend to get some at a dark spot. Living in Los Angeles, there's light everywhere.Any pictures of the output pattern at night from inside the cab?
Its just some angle iron i cut to fit the steel peice behind the lower grill and I bought the light bar with adjustable mounting screws so u can slide them in or outWhat brackets did you use for your 30” behind the lower grill?? I have a 30” Baja designs onyx6+ I need to get mounted up!! I didn’t see any for that location on zroadz
Yea I hate the hardware too but I had no time as I had a 12 hour trip the following day lol got around 15.5 mpg total for 1700 miles. I'm considering getting spots now rather than floods.kinda scary how close that light pod bolt is from touching the hood. I'm on the fence on putting them on my truck. I have the KC mini pod, i just need to buy the mount.
I zip tied it next to the footwell light. I didnt want to drill any holes and I also tied both relays to turn on with one switch rather than having two switchesWhere did you put your switch(s)?
I was looking into getting the cubes for my rebel and was curious if the pods came with a rock guard/light cover. trying to avoid the ticket here in CA.I finally installed a light bar hidden behind the mesh above the skid plate of my Rebel and some LED pods that go mounted on the hood hinges and run up by the A pillar.
Why would you get a ticket?I was looking into getting the cubes for my rebel and was curious if the pods came with a rock guard/light cover. trying to avoid the ticket here in CA.
