30" Light bar and 4" led pods
RamRebelSteel
Los Angeles
I finally installed a light bar hidden behind the mesh above the skid plate of my Rebel and some LED pods that go mounted on the hood hinges and run up by the A pillar.
j517
Nice
RamRebelSteel
Los Angeles
Any pics of the hood pods turned off? I'd like to seem some shots of those.
I bought some off Amazon just to test waters. Wasn't sure if I was going to like hood pods but I like it a lot! Now doing some research for better pods. Maybe Baja design XL Pro
dorskh
What brackets did you use for your 30” behind the lower grill?? I have a 30” Baja designs onyx6+ I need to get mounted up!! I didn’t see any for that location on zroadz
RamRebelSteel
Los Angeles
Its just some angle iron i cut to fit the steel peice behind the lower grill and I bought the light bar with adjustable mounting screws so u can slide them in or out
limited_19
kinda scary how close that light pod bolt is from touching the hood. I'm on the fence on putting them on my truck. I have the KC mini pod, i just need to buy the mount.
RamRebelSteel
Los Angeles
Yea I hate the hardware too but I had no time as I had a 12 hour trip the following day lol got around 15.5 mpg total for 1700 miles. I'm considering getting spots now rather than floods.
OuachitaAdventure
I had those same brackets on my 2500. They are a little pricey, but they are good quality and you can adjust them to where they leave a little gap between the hood. If you're wanting pods on the hood those brackets are the way to go.
Here's a video on the ones for the 2500 which are basically the same, just a little different bend.
B-Rebel
I was looking into getting the cubes for my rebel and was curious if the pods came with a rock guard/light cover. trying to avoid the ticket here in CA.
brotharon
Seabrook, Texas
I am wondering if there is a way these could be mounted on the arms of the mirrors. Seems like there is a whole lotta real estate there that I could tap into. Getting power to them might be a little trickier, and it is possible that it cant be done with the power folding and heat and whatever else is in there, but i think it sounds good in my head...
