3.92 vs 3.21
Ram408
I have a 2016 Ram CC hemi 4x4 Sport with the 3.21 rear. At 75mph on flat roadway, in 8th gear, my engine is purring along at approx 1650rpm’s. I have yet to order a 2019 limited and I’m split on which rear to get. Could any of you that already took delivery of your trucks, tell me what your engine rpm’s are at 75mph? I’m so curious to see how much higher it will be on a 3.92 geared truck. Thank you so much for any help!
firecadet613
I'm about 1650-1700rpms at 75mph. Very pleased with the 3.21s, although I will say I was going back and forth before I ordered and even after I took delivery. It took a long roadtrip for me to be fully sold on the 3.21s.
19llhpb
North Central Indiana
I will take a run in my truck here after bit and let you know the rpm’s of a 3:92. I am going to get a lift and 35” tires hence I got the 3:92’s. If my calculations are correct, :unsure: running the stock 275/55/r20’s with the 3:92’s would be equivalent to a 3:58 rear axle ratio with 35’s. So I will still be ‘torquier’ so to speak than the 3:21’s stock. If that makes sense.
19llhpb
Ok, here we are. ‘19 Ram with 8 speed tranny and 3:92’s. Mph and rpm’s in 8th gear.
55mph 1500rpm
65mph 1750-1800rpm
75mph 2025-2075rpm
