3.5" Rough Country with factory 22's
terrywarfield
Wanted to share photos of the lift and new tires using stock 22's since I couldnt find many samples. Wasn't in the market to also buy new rims
Ended up going with Rough Country 3.5" lift (M1 struts), and Venom Power Terra Hunter XT, T35X12.50R22LT + .25 ready lift Spacers all around since the factory rims have a positive offset. Didnt want the tires sticking out a ton. These clear the fenders just a tad. No cutting was necessary either
For sure an immediate difference in acceleration and power output difference now tho, of course engine working harder
Looks good! Did you calibrate the speedo also?
Looks nice. How do you feel about the ride compared to stock?
Also, it's hard to gauge visual difference between stock, would you mind getting a few pics next to a stock Ram?
I'm currently on a 2" level and 285/50/22 Recon Grapplers and am kicking around going to the 3.5" RC kit.
I’ve been looking at this kit but had seen the negative comments about it and the concerns for safety. How has it been for you.
Just installed the same M1 kit today on mine. Is yours nose high? Install went fine, but my rear end is still a bit sagging. I've read others ended up doing a 2" rear spacer instead of the 1".
