3 1/2 in. Lift on ram 1500 with 35/12.5/20
Nice truck! so if you have the off-road group you essentially would have 2" in the rear am I correct with this kit?
I had RC 3.5"s kit installed with N3 struts and V2 rear shocks on a 2020 RAM 1500 with off-road package. After install the front is 1" taller than the rear. The rake to the rear looks bad. I'm also concerned about my CV angles as the distance between the center of the wheel and fender is 26". Rough Country states on their website that this package fits fine with the off-road package but here we are.... Has anyone had a fix for this? Ideally I'd like to lower the front an inch so the CV angles aren't so abrupt.
I am getting ready to install the exact same setup, same exact truck except longer bed, and same size tires. I have the weather tech mud flaps and hope to keep them on.......... but I have my doubts
Great question!
You are correct, I am only using the Icon springs in the rear, trashed the rear blocks from the kit. I’m not sure what their height was but I can say the rear sits about 1/2” lower than the front with this set up. I didn’t want to have to use any spacers, that was my main reason. Hoping a 2” lift rear spring comes out that I could maybe switch to.
How is the towing with the icon rear coils?
