2mm offset on 275/60R20?
kingcole
oregon
Hi everyone. Newbie question alert.
I’m trying to wrap my head around offset numbers, and ran across some 20” Fuel wheels, 2mm offset, with 275/60R20 AT tires that have me thinking about buying them.
I’m trying to find a 33” total package that sticks out about 1” from the stock setup. Would I be close with this setup? And, while I plan to level the truck in the near future, would these likely rub with the stock raked ride height in the front?
Thanks for the help with this!
Choate
It’ll be fine. Very common set up. I had that same thing on my stock truck
LaxDfns15
Memphis, TN
That setup will fit fine as the Rebels have that tire size stock with 18's (275/70R18). It's close to moving out 1" from stock, but still only 17mm (about 0.7 inches).
Tlaug01
Here is almost exactly what you are wanting. These are 20x9 with a 0 offset. 275/60/20 all terrains. Stock suspension. No rub at all. 5DFE131C-C86E-4978-8AFC-7B3E9CB5E65A.jpeg
