My backcountry has the same setup (2021 models was the north edition, then in 2022 changed it to back country). And my aftermarket fuel 20" rim and I run those tires with no issues. I have aftermarket mud flaps and I had to trim the inside ever so slightly because at full lock it would rub. If I didn't have those flaps, I would be fineHas anyone run these tires on a stock 5th gen 1500 or north edition (factory 1" lift) and had any issues with fitment or rubbing? Thanks in advance.
I've been researching this tire size for my stock '23 Longhorn (no air suspension). It seems, second to lift/leveling, wheel offset is the most critical fitment factor. Wonder what offset your wheels have and what is your best guess for trimming-less offset.My backcountry has the same setup (2021 models was the north edition, then in 2022 changed it to back country). And my aftermarket fuel 20" rim and I run those tires with no issues. I have aftermarket mud flaps and I had to trim the inside ever so slightly because at full lock it would rub. If I didn't have those flaps, I would be fine
My question to you comes down to the rims you have.
2016 Dodge Charger scat pack
You are right the offset is important. My offset is +1...so it's super close to stock rims.I've been researching this tire size for my stock '23 Longhorn (no air suspension). It seems, second to lift/leveling, wheel offset is the most critical fitment factor. Wonder what offset your wheels have and what is your best guess for trimming-less offset.
Got 2" of lift just on tires alone...lol
Here is another "official" data point that I have that can help as well with the upper control arm...lol+2" diameter ==> +1" lift . My 285/45R22 are dwarfed by the wheel arches. Looking forward to installing these particular tires. If I could only catch a 4th of July sale.
Thanks for the data point. I did come across a setup with +10 offset with no rubbing, but they didn't have aftermarket mud flaps.
I don't have anything to add to this thread other than, I'm not normally a fan of colors on wheels, but that blue really flows with the blue truck. Nice little touch.Here is another "official" data point that I have that can help as well with the upper control arm...lol
