22” oem wheels paired with ...
Mine will be installed Tuesday as long as I finish installing the lift. 22” ridge grapplers
^^. Which lift are you referring to please ?
While in New Mexico
Anyone running stock 22 rims with 34" or 35" tires with factory Air Ride? Pics? Issues?
35x12.5r22 mileatar patagonia mt
No air ride
2 in level
Some wheel well trim
Minor rub at full turn w articulation
Kind of a long shot but is anyone running the Bridgestone Dueler A/T Revo 2 tires on 22in rims with no lift or air suspension? had them on my old ram which had 20in rims im not sure if they will fit well or if they would rub
No air ride
2 in level
Great looking truck...exactly like mine, same options but I have air ride so I'm concerned about going to 35's might do 34"s.
THANK YOU! ... the tires measure exactly 34 inches tall with the weight of the truck on them @ 48 PSI. That is what I recalibrated the speedometer at to get it to match GPS speed
I'm looking for some tire recommendations for the stock 22" rims with Air Ride as well. Need some winter tires that will handle snow alot better then the stock all seasons.
So after running the Patagonia's for a while, how do you like them?
Ridge grapplers 35 x 12.5 R22. I rub in normal (full lock) with Daystar spacers and revel links.
Looking to do the same! What size spacers are you running? do you have the revel links at max? How much did it actually lift the truck?
Nice Build!
Nice Build!
No wheel spacers, only the Daystar spacers for suspension, not sure about the links. I just kept adjusting until it was even with the stock rear.
Truck could use a 4" lift.
So far so good, I have just under 17k on them, tread looks good. The only issue was a huge bolt I picked up in one of them that couldn't be patched and had to be replaced. Not the tire's fault tho...F-ing construction zones.
