2025 tow rating
MT755
Has anyone seen the towing capacity or gcwr chart for the 2025's. The max towing has been posted everywhere but nothing about a Tungsten 4x4 crewcab with the gear ratios available. The max towing advertised would be for a stripped down 4x2.
JF19Longhorn
South Jersey
I have not, but payload is what you really need to be worried about on the higher level trims.
Towing can state 20k lbs, but if your payload is 900lbs, you aren't getting anywhere close to that.
MT755
Thank goodness for weight distribution hitches
