2025 Ram Rebel Air bag light on when cold emergency sos on screen
Musickdude
When it gets below freezing and you auto start truck the air bag light is on and the screen says emergency sos disabled. I took it to the dealer they said if the light is not on then they can not even generate a repair order. I used a code reader and received code B0095. The code description is right front restraints sensor : internal electronic failure. I tried to clear it and it would not clear. I called Ram hotline and they gave me a case number. After a week or so hearing nothing I called back and was told they only handle Connect radio problems. total waste of time. I was a Factory trained Ford technician for over 15 years and did this type of diagnostics every day. I have been told several times from the dealer that when the service advisor hooks up the pod and no codes or lights are presented no actions can be taken. When I auto start my truck when temperatures are below freezing the light stays on and truck says SOS activation on the screen. After at least two key cycles it will go away. it does not happen with above freezing temperatures. I took a trip and it happened multiple times . Im worried that while driving my air bag system will not function properly and could result in no airbag deployments. I have reached out to the service manager for help and was told when a loaner vehicle is available I can bring it in and see if codes are recorded. any HELP would be greatly appreciated
What B0095- number, 11,12,13 or 49? -11 is short to ground, -12is short to battery, -13 is open circuit in ORC , impact sensor or wiring and the B0095-49 is
"B0095-49-RIGHT FRONTAL ACCELERATION SENSOR-INTERNAL ELECTRONIC FAILURE" Pardon the font size...
This is on my 2019. From ALLDatadiy.
