racing4holli
- Dec 22, 2024
Is there a way to get a list of all the standard and optional equipment on my truck. Does anyone know if all longhorns have adaptive headlights
Do you already have the truck or is it an order still waiting to be built? I was able to get a build sheet eventually after my truck finished production by emailing Ram US customer care but also found a listing of this info once I added the truck to my Mopar account and looked under installed equipmentIs there a way to get a list of all the standard and optional equipment on my truck. Does anyone know if all longhorns have adaptive headlights
For some reason the build sheet link no longer works for 2025 model year trucks - you just get a PDF that says VIN unsupported.Your build sheet will list all that information. You can pull your build sheet using this website. You only need to enter your VIN...
FCA RAM
fcagroup.my.site.com
Your window sticker will list most standard features as well as optional equipment but isn't as detailed as the build sheet. You can pull up your window sticker with this url. Just add your VIN to the end of the url after the = sign...
Thanks for the info. I wasn't aware that was the case for 2025 models. Looks like the window sticker link works for them though.For some reason the build sheet link no longer works for 2025 model year trucks - you just get a PDF that says VIN unsupported.
Correct - still able to pull a window sticker (although they don't show a ton of detail on the packages) but the only way I was able to get a build sheet was through customer service. I will say the equipment listing in the mopar app was basically the same thing but I always liked having the full pdf document.Thanks for the info. I wasn't aware that was the case for 2025 models. Looks like the window sticker link works for them though.
