2025 1500 tow mirrors
I received my new mirrors in yesterday and got them installed this morning. Very easy job just take your time with the clips. Everything works from the turn signals, blind spot, heating element and power adjustment. Only thing that does not work is the power fold. Hopefully AlpahOBD in the future will allow me to turn on the function.
Gday - did you ever get the fold feature enabled? I assume you had that option/button on the big mirrors?
oh - and is that 'arm' of the mirror a bit fatter on the tow mirror also?
Has anyone replaced just the mirror glass? The blind spots are an issue for me as well, but the bigger issue is how terrible the glass is (on the passenger side especially). The convex mirror is absolutely fine but the "main" part of the mirror is absolutely useless.
Are the part numbers you included for the black painted mirrors?
I almost purchased a bighorn but didn't because it didn't have the tow mirrors. The salesman and myself chatted with the parts dept manager about what it would take to swap them out and the parts came to about $700 but all parts showed backorder with no eta. This led to me buying the warlock instead my boat trailer is 9ft wide I need the tow mirrors.
How do you tow a 9’ boat legally. Legal width is 102” or 8’ 6” . You would need an over width permit.
I’m very interested in your information on which part number or mirror did you replace your tow mirrors with. I really dislike the blind spots
Has anyone with a ‘25+ Sport (Canada only trim) or higher trims tried swapping out the painted regular mirror that’s fully loaded (with power fold) to tow mirrors with fold? Are they plug and play or would need reprogramming at the dealership since Tazer, Alpha, JScan doesn’t work yet on these newer trucks? Power extend isn’ta concern for me but needs to retain power fold.
Looking to buy a set at my local dealership (if I can’t find someone locally to swap with) but need to make sure. I know I’d need a set of tow mirrors and door buttons panel correct?
68569561AC
68569554AC
These are the black painted mirrors I purchased without the cameras. They are power-fold which requires programming. I am not sure if programming is available. All other features such as adjusting the mirror itself, turn signals, and blind spot work plug and play.
Here are the part numbers for 2025+ sport mirrors WITH cameras, power fold, blind spot, etc. Just got them for my dad's truck to replace his tow mirrors.
7JR49KXJAD
7JX72KXJAC
Got both off ebay brand new for a few hundred bucks cheaper than what the dealer wanted.
Has anyone tried this swap on a 25" Tungsten? Parts guy is convinced the clips are different and wont plug in at all.
Yes, i have a tungsten that i bought used. The owner before me had the swap, and the standard mirrors were still on it when i first looked at it. They fit, looked, and worked perfectly. Unfortunately he kept them and put them on his 26 tungsten, and I got the 25 with the factory tow mirrors.
