tigunin
- Jan 16, 2021
Hey, everybody. Got a question. 2023 Ram 3500 Crew Cab & Chassis. Installed everything as prescribed, did it already on another one of these same trucks only 2020 and everything works so far without a single problem. Everything is done, I check the handle works, it takes a while, maybe 10-15 minutes and the door handle stops working, I turn on the ignition, go into the machine settings turn off the passive entry, turn off the ignition, turn on again go into the menu and turn on the passive entry and the handle works again then 10-15 minutes and stops. Need to find a solution. Thank you all!
