2023 Limited RED Edition (Black Out Sport) with OEM 22's wrapped in LT295/55 R 22 Toyo Open Country AT/3
jokingjimmy
I just picked up my 2023 Limited RED Edition a couple weeks ago. Mine had the OEM spec Pirelli Verde A/S in 285/45R22 M+S (no really, it's marked M+S lol) with no off-road group and 3.21 rear end.
I have spent way too many hours researching and trying to decide on tires. I wanted a tire that was rated to perform in the winter, snow and ice (3PMS), performed better in light to medium off-roading but really did better than the rest on long highway drives. Finally chose to keep the OEM stock 22x9 black Y-spoke wheels. I really like the y-spoke design, I have to admit! Replaced the Pirelli Verde A/S 285/45 R22 with Toyo Open Country AT/3 LT 295/55 R22 = 34.8" x 12.2" @ 62 lbs each. Wanted LT vs Floaters for several reasons. I don't do serious off-roading or rock climbing, prefer the lighter tire weight (73lbs for 35/12.50 vs 62 lbs for the LT295s), the heavier load range for future towing and the speed rating. Again, I only do light off-roading, snow driving and gravel stuff - mostly city and highway with 3-4 2k highway trips (family at holidays) per year. Originally was looking more for a 33 x 12.5 but was worried about the specs, and that unsprung weight. OK how they look was a consideration as well
My comments regarding this setup.
  1. Fit - First question I'm sure is "Do they fit?" Answer - No rubbing in Normal through OR2 drive modes (2/5 thru 5/5). I installed Husky brand mud flaps, and unfortunately they do rub on the driver's side mud flap at 2/5 and 3/5 (Aero and Normal) ride height only when turning left 80%ish (not full lock, nor in any other ride height). I installed Revel level kit (front only) and took a heat gun to the one mud flap and basically worked down the spot where it protrudes into the wheel well and "kisses" the tire at partial left turn. See pick with the blue arrow, that little 1/2" section is the only rub with flaps on.
  2. Noise - Next question "Are they loud?" I did not use a sound meter, so this is somewhat subjective. I noticed a roughly 5% add in road noise. Not very much at all, I could barely hear it with radio playing at "medium" levels, and when turned off it was slightly noticeable. However, I was really hyper-focused and paying close attention. So what I mean is, it was noticeable at first, and if I really listened for it, I could hear it. Now that I've driven it a little, I don't notice it at all, and so for me, zero issue. YMMV. I just say it this way because anyone that said they couldn't hear the tires at all, well need their hearing checked Stock OEM Pirellis are car-quiet.
  3. The Ride
    1. Handling - With the stock Pirellis on, this truck drives like a sporty SUV. Not much body roll , even at speed on highway and in curves/corners. It doesn't plow into cornering at speed, surprisingly responsive steering. With the Toyos installed, there is a slight softening to the handling, so little I hate to mention it, but it the difference is there. Still MUCH better than my previous F150 XLT with FX4 package with the stock Hancooks, but I would say about 5% less solid when it comes to body roll feel that the stock Pirellis. Like I said, much better than my previous truck, and really barely noticeable.
    2. Comfort - I know that LT tires are supposed to be a slight rougher or harder ride, but frankly they seem to ride exactly the same as the OEM Pirellis. Again, in curves and swerving a tad slushier, but over bumps and on roads and highways, about the same - pretty amazing. Assuming that has to do with the air ride suspension (I had bagged and modded cars in the past, gimme bags or gimme death )
      1. Ride height - I will say that at 2/5 height, the ride is almost identical in comfort smoothness to the OEM tires, and the affect on curves and swerving is noticeably the least. 3/5 is super close, so it works well riding in 3/5 then letting it drop down to 2/5 for the higher speed stuff. 4/5 and 5/5 is where the ride is noticeably springier and less steady than stock tires - the higher the worse. I don't drive pavement in these two modes anyways, so not an issue. Just sharing an insight.
  4. Traction - No scientific method here. Basically, I punched it a few times, both turning from a stop and going straight and the tire broke loose a little. Granted they are new tires so it's probably equivalent. It did rain and snow in the past couple of weeks and I will say the traction seems better in the wet (un-scientific moguls on deserted street) and then snow stuff. Overall feels more grippy than OEM all seasons - which they should.
  5. Power/performance - Off the line, it feels a little sluggish, like the rotating mass is affecting take-off. at speed, say 30 MPH, butt dyno doesn't feel any difference, but at a stop light, or at highway speeds, it's noticeable if slight. It's actually not as bad as I expected from reading online reviews though, so pretty happy here.
  6. Looks - for my taste, I think they're fantastic - I had the "cool side" mounted to show. They actually look quite a bit different - and much better - in person. Photos don't seem to capture the essence of how these tires look. All the pics I saw of this tire brand and size looked just good. But in person, they look great.
  7. Made in USA. If that's important to you, now you know.
Summary - I think if you want a truck that drives and performs like a station wagon or sporty SUV, stock tires are actually pretty great for that. But if you want that, plus some off-roading and much better looks, totally a good choice going with these Toyos. If you really want true off-road capability and the look of a beefy off-road wheel & tire setup though, might want to consider dropping to a 20" or even 18" wheel size. For me, I really love the look of these 22 inch wheels wrapped in an LT tire that's "just under" 35x12.50. Yes, no regrets and I'd definitely do it again. But, as always, YMMV.
Hope this helps someone.
Before/After
NOTE: Left pic is full lock, no rubbing. At about 70-80% to full lock, wheel touches the plastic protruding piece from the mud guards.
jokingjimmy
IMG_1631.jpeg In case anyone is interested, a quick update. Verified that the rubbing is happening due to the Husky Mud flap (Drivers side only at left turn). Here's a pic with the mud flap removed.
Since i did want to keep the flaps, used a heat gun to soften the plastic and bent the wheel liner back about 1/2". Then applied heat to the wheel liner. It's less pliable since it's rubbery and softer (counter intuitive i know) so I did a combo of reforming the mud flap and scraping about 1/8" of material - this was accidental since the flap plastic material got so soft some scarred by accident lol.
Anyways, YMMV but it seems there's no rubbing in stock at aero, normal, OR 1&2 ride height with no modification. With the little work i did to yhe mudflap (only took about 10 minutes all in) also all modes no rubbing - even aero - lock to lock with mud flaps installed.
rcsnow82
TN
This is great! I was considering these and this size and this is very helpful. Sorry if I missed it, but how much MPG hit have you take?
jokingjimmy
So far it's significant. About 13-14 mpg on the highway averaging 75-80 mph. Like 11 in town with a semi-heavy foot. I was getting about 16-17 with the stock tires. I'm 1,600 miles on the clock so not sure of it's broken in yet - read a few posts stating that mpg increases after some mileage.
Interesting thing is that with my 3.21 rear end, I read that I would spend most my life in 7th gear with the heavier bigger tires, but I'm in 8th quite a bit more than I expected. I would say 40% of the time when paying attention. Downhill, level and very slight uphill even. Truck seems to run similar to when i had stock tires on (based on feeling, not actually timing anything). From what I understand, 7th gear ratio is supposed to be close to the 8th gear with a 3.92 rear end, so aside from lower gear acceleration 3.21 seems to be ok. Just a side thought there lol.
Good luck!
Jeremy47
Cypress, TX
After doing a TON of research on “will it fit” or not, I stumbled across this post and it helped me come to the decision of going with the Toyo Open Country AT/3 LT 295/55 R22’s.
Thanks again @jokingjimmy for such a great write up! I love these tires.
I do have a front level kit from Airlinks Suspension which is still about a 1/2” lower than the rear.
