Hey guys 2 weeks ago I had the Fabtech 3 inch level lift installed on my 2022 rebel I had the wheels and tires put on at the shop on same day. The wheels are fuel rebel and the tires are bottom ridge grappler size is 18x9 for the wheels and the tires are 35x12.50r18. The second I pulled up to the shop to pick up the truck I was amazed at how good it looked. I do a walk around and I’m soles at how good it looks I jump in the truck to drive home and immediately I realize this truck is driving extremely stiff. Every little crack and bump in the road I can feel very harshly. I was really upset at how stiff the ride was. I start to look more into the tires after I get home and I realize these nittos are load F 12 ply i check my tire pressure and it’s reading 60 in front and 50 in rear. I called Nitto and they said to lower the psi to 48 in front and 39 in rear. After I adjusted the psi the ride became so much better but it’s still not where I’d like it to be as far as stiffness or in this case being over stiff. Everywhere I call the first they say is that the load f 12ply tire should only be for a 2500 or 3500 truck but that it can be ram on a 1500 truck but it will be very stiff. I am miserable after spending $5,000 between wheels tires lift kit and installation the truck in my opinion runs like s*** my options are to order a new set of tires which I’m thinking bf Goodrich all terrains ko2 and just trying to sell the nitto ridge grapplers which only have 500 miles on them. I called the shop and they told me that the nittos in that size only come in load f 12 ply but they figured I knew that since I requested that tire. I was not aware of that I just picked the Nitto Because I liked the look. What do you guys recommend I am open to ideas. Please help and let me know what I should do as far as changing this set up I really think the lift itself is great and paired with the right tires would give me the look I love with a stock lime ride quality.
