2022 Ram GT - Rebel or Laramie Dyno?
Here's a shot from a week ago. Fastest 1/4 time was with the Pulsar in Performance mode. Interestingly, my quickest 1/8 mile was in stock mode, but I didn't make enough runs to see if there was a pattern
Wow, that's .4 secs faster in the 0-60 time and 1 sec better in the 1/4 miles times with same trap speed.
That is substantial!!
Did you happen to get a picture of the Dyno results just for comparison?
Also, does the pulsar have a stock settings for apples to apples comparison?
Yes the pulsar has performance stock and economy settings. I didn't even think to get a picture of the Dyno results. I have since removed my Pulsar so I can't tell you what that would look like, Wish I would've run those graphs before I did that
Can you do a run with your stock PCM?
And just curiosity.......why did you remove the Pulsar daughter board?
Ive ran a 9.3 1/8 mile time with my 2020 Built to Serve at my local drag strip with stock PCM, and stock wheels/tires. After my Vararam install I have logged a 6.1 0-60 time using the TazerDT 0-60 timer. Haven't been able to match that since the day of the install. Just a few weeks ago, with Pulsar in performance mode, Bilstien front level, and 34" tires(stock were 32") I ran a 9.5 1/8 mile time at my local drag strip.
This was last summer in 90 degree temps at 1/4 mile drag strip in Oklahoma. Stock wheels/tires. Pulsar in performance mode. And my truck weight from scale at track.
I feel like I get a better launch with this GT than I did with the Big Horn. Maybe it's the wider tire, maybe the added weight. If/when Edge gets the Pulsar figured out for the GT I might reinstall and make some serious runs
Nice runs, it's good to see the Uconnect 5 performance pages times are inline with a real drag strip!
anyone know the magic trick to get the truck to successfully save performance data to a USB key? The truck recognizes it's there but gives an error any time I try to write data to it.
not sure of trick but I had the same problem.....thought it was because I use a Mac but I tried 3 different thumb drive and one work. Provides nice images.....saw 357 hp on the horsepower / torque analog display, but was hard to capture real-time because readouts are so dynamic
