2022 RAM 1500 not starting
biznelison
Hi all,
Wondering if anyone has had an experience like this:
Yesterday I shut my truck off in the driveway like normal. 10 minutes later I came out to drive somewhere and the truck would not start. The brake petal was impossible to press in. Remote start would not work. If I switched the ignition to RUN the dash would cycle through several warning messages:
  • Electrionic throttle control warning
  • Electric park brake warning
  • Service Electronic Stability control syystem
  • Service airbag system
  • Speed control messaging error
I disconnected one terminal of the battery and tried again but got the same result. After about 15 minutes I was about to call roadside assistance but the engine magically started before I hit "send". I received no warning messages when it finally started. Any insight on what might have caused this would be greatly appreciated.
Had similar issue today. Drove to work this morning, parked, worked for 2-3 hrs, came outside and the Truck won't start. It is a 2022 Laramie Knight with 5.7 and eTorque.
you could not press on brake.
A button-auto start stop was on.
Battery had power.
so frustrating...this is a brand new truck with 6,500 miles. I had it towed by Chrysler affiliate and a dealer is looking at it.
Happened to me on Monday. Radio was all wonky also. been fine since. Just over 1500 miles.
I wonder if this is related to a Forced Over The Air Update (FOTA) - Mine did one this past weekend, and the truck acted pretty funky at that time. Ram suggests you don't drive the truck while this is occurring, and that it can take minutes to hours to days for everything to return to normal (actually, they don't say it quite like that... Most of my system returned to normal Saturday afternoon, but my compass didn't show up until yesterday).
Battery had power.
Mine's been at the dealer all day. Last I heard from them they essentially said nothing is wrong but want to look at it more tomorrow. Any word on yours?
Just had mine towed to the shop for this issue. I will keep everyone posted on what they find and the fix.
Hi all,
Did you find what was rong whit cuz mine done the same thing today and i dont no were to start thx
Had the same problem with my 2022 1500 5.7 Laramie on Saturday. Completely dead, had to tow to dealership this morning. Truck is less than 2 years old with 19k miles. Anyone get the root cause of this issue from the dealership that fixed it?
Anyone figure this out? I have 22 ram 1500 bighorn and now have this starting problem to! I’ve had battery and alternator tested good. Happens out of the blue 3 times now in the past week. I’m out of warranty so would like to know something about it
Im having this same issue. First my heat stopped working and was just blowing cold air, I parked it and checked all my fluids, which all was good.
After work it started up no problem. Drove it for maybe 20 minutes and then when I pressed on the gas, the coolant temperature rose immediately and started bouncing around from left to right.
I parked the truck and I haven’t been able to start it since.
All electronics work, I replaced the battery and checked the wires going to the starter and everything was snug.
I tried scanning with my autel computer but I’m not getting any codes.
Did anyone figure out why it’s doing this?
Did the dealer say anything? As I am out of warranty and don’t want to run up a hefty bill with them if I can maybe do it myself.
Any update. I am dealing with this right now. Car is completely dead. Try to charge batter only thing that works is the anti theft.
