2022 1500 Limited - Battery Drain issue?
snearylaw
Redmond, Oregon
About 55k miles on the truck. During this winter periodicially the truck wouldn't start (parked outside in the cold/snow). A quick jump did the trick so I figured it was the battery. That was replaced last week but I am still getting intermittent times where it needs a jump even with the new battery now. The truck has power (radio turns on, power running boards deploy, etc.) but just makes a single click when trying to start. The dealership is a month out so any assistance in the meantime is appreciated! Thanks.
Ever find a solution to this? Seems to be draining quite a bit some days and not other days. Thinking it may be my rf hub or IBS sensor. 22 Limited 1500 with 26,000 miles. Replaced truck's battery, charged it the correct way (through the ibs). I keep getting unresponsive keyfob and sometimes it unlocks when I grab the handle, sometimes I have to use the button on the fob, other times it takes 5 or 10 tries. I have walked up to the truck and had it unlock repeatedly from 5ft behind the bed. Every time it acts up, the battery is slightly low like 12.5v and after charging its fine for a while. I did have a rear window leak but fixed that in the spring and just started acting up this winter.
