2022 1500 eco diesel acc and batt fuse box location
bostonbruin44
Hello All,
I am hooking up a hard wired dash cam to a 2022 1500 Big Horn. With two connections, one while the engine is on and the other with the truck off for constant surveillance.
My fuse box says that the F54 A&B are for
A. Power Outlet Center Seat Battery Feed Position
B. Power Outlet Center Seat Ignition Feed Position
Those might be for an older model.
What I'm guessing is the following:
F57 20 Amp Blue – Direct Battery Feed * "for the constant on"
F58 20 Amp Blue – Direct Battery Feed *
F66 – 10 Amp Red Run - Accessory Feed "for the ACC on while driving"
Has anyone hooked up a dash cam to a 2022 with this type of fuse box?
Any help would be appreciated. I have attached my manual fuse information.
Thanks!
John
I’m not good at searching in the forum yet. I found the answer from Moparleo51. Thank you for the great information.
“Constant 12V is F33, switched 12V is F66.”
Hope that is right and can help someone else.
John
