2021 Ram Rebel - Leveling Kit
Cheapest non puck level for the Rebel is Bilstein 5100s in the front.
Probably. And they(and those like them) are valved to handle the lift and larger wheels. Making them a much better choice than pucks.
What offset did you go with to accommodate the 35x12.5?
I had -12 offset wheels. It rubbed slightly on the tiny factory mudflap that came on the truck. I removed the mudflap and drilled two small holes in the wheel well liner to put a zip tie through and pull the liner back. The latter was more of a preventative measure to make sure the tire never caught on the wheel well liner since it was partially held in place by the mudflap if I recall correctly.
I did exactly what you said, RL 2” with the new new UCA & stuffed some 35’s on the stock rims. Rides awesome, not even close to rubbing. Only thing if you wanna get nit picky is the front is 1/2“ higher than the rear. But all in all, love it. Have a 2022 Rebel. Local reputable custom shop did the work.
Do you have any pictures of how close your tire is to the UCA? Im on 305/70/18 on stock wheels with a 2.5 front and 1.5 rear lift. Mine rubs some and im curious if your taller/wider tire does too
About an inch.
Dang. Do the rough country control arms have bigger ball joints?
What in the world? That's weird on those control arms. How do you like the ready lift? Do they provide more clearance?
rubbing on UCA is not a lift issue, but a wheel offset issue.
you should have at least -12mm offset, or 4.5" backspacing to clear most UCA with tires wider than stock spec.
lifts do not gain you clearance, but bigger tires do. this is because your lowest point, aka your diff, dictates your ground clearance. 33 to 35 you gain 1 inch of clearance, not two. 35 to 37 you gain another 1".
also, avoid puck lifts
This^^^ should be a sticky.
