Hey All - First off thank you for everyone who contributes to this forum. From getting a good deal on my truck to learning how to level my truck I have found so much valuable information here.
It took me a bit of research to see determine how I could fit 35's on my truck and if I could do it with the stock 22" wheels so I thought I might post this to help others out in my position.
This is a 2021 Ram Limited 1500 Night Edition. No off road package and of course it has Air Suspension.
For those who don't know there are fewer lifting options for this truck due to the air suspension. Please make sure if you are looking at lift kits that you validate that it works with the air suspension model.
I ended up going with the Revel Performance Links on the front with the Daystar Spacers. The links take under 10 minutes to install. Super easy, super simple and you do get drivable results and a close to level truck. We instantly liked the stance of the truck better once the links were on. The links essentially inflate your airbags on the front to give you a higher ride height. So you are driving with air bags that are inflated on the front end the entire time making the drive not as smooth. To fix this you can then install the daystar spacers and that compresses the air bags back down bringing your ride very close to stock with the desired leveled appearance. The spacers took me about 5 hours. 3 Hours for the first side and about 1 hour and 45 minutes on the other side. Others have reportedly done it much quicker. This was my first time doing this kind of work so I took my time.
I only installed the front spacers and the front links. I did not install rear links. I have them so I will probably list them for sale on this forum eventually.
Today I put the 35x12.5xR22 Nitto Ridge Terra Grapplers on her. She would rub at full turn in Entry/exit mode but she does not rub in any other modes. I rarely use entry/exit mode so I simply don't mind that issue. Discount tire was happy to fit one of the tires on at no cost to ensure I was happy with it and the clearance wasn't an issue.
Is it louder? Sure. Is it as loud as other tires in this category, defiantly not. These tires run about 500 each currently so its not a cheap jump.
Overall I am very happy with the end result.
Feel free to ask me any questions you may have and I will do my best to answer them.
View attachment 105233View attachment 105234View attachment 105235
