I have a 2021 ram 1500 limited with 22's, 4x2.
my dumba$$ in alpha obd clicked "set sensor height" thinking i could use that to level the truck and while you can it wiped the calibration.
i found the DS calibration procedure but it keeps setting the truck super low, i've got it set so its about 1" lower than it used to be and it stopped resting on the bump stops but i'd like to perform the correct procedure for the DT ram model.
Thanks.
Thanks.
