2021 LED Headlights (factory), Driver Side Intermittently Not Working.
domestique
Hello,
I have a 2021 Ram 1500 Big Horn (less than 30K, a little over 800 engine hours). Everything electrical is stock, except for a dashcam and LEER cap that was installed a couple months ago.
Problem:
Two nights ago I noticed my driver side headlight (factory LED, non-projection) wasn't working. The next day I went out to investigate, and everything was working fine. Today, I encountered the same problem. I am HOPING it is something electrical in the connection and NOT the whole headlight assembly, those alone are close to 1k for OEM.
*I have zero warning lights.
Does anyone have any troubleshooting advice to look at before I take it to the dealership?
Update. I was able to trace back the harness, and the one connector was able to be pushed in.... so far everything is working again.
Not to wait and see if that was truly it, and not something worse (like a faulty BCM)
If you don't mind my asking, where was that connector you found located? Not right next to the headlight?
Thanks
