Forgive me if this there's already a thread for this, but I could not find one.
I have a 2021 1500 Limited with just under 80k miles on it. Since I've had it I have had to change tires about every 20k miles because the outside of the tires wear away. Everytime I get the oil changed I have to get it re-aligned.
I had an issue with the steering gear that needed replaced, and the hope was that fixing that would fix the issue, but it has not fixed the issue that it continually needs realigned.
I disabled the aerodynamic mode to keep the vehicle at the same level in hopes that might resolve it. This does not work either.
I have the extended 3rd party warranty through 100k miles, so I'd like to get this resolved, but I also can't just drop this off at the dealer for a week+ because they won't give me a loaner.
I do drive on some dirt and gravel roads, but I'm not slamming pot holes or anything that would cause me to the truck to come out of alignment regularly. Before this I had a 2017 1500 Laramie that did not have this issue on the same roads.
Any help would be greatly appreciated.
Thanks
Thanks
