Yesterday me and wife smelled this horrid smell yesterday driving from Illinois to Indiana and assumed my daughter had her shoes off, she did not. My truck is one year old with 4,200 miles with this smell. I doubt my drain is blocked. Here is what Im going to try (2) things as two members pointed out.
(1st)
Mikeru82 suggest this to clean the vents/hvac from mold/bacteria which I feel is happening bc Ram's oem filter is too cheap and not doing its job. I'm going to use Lysol.
If your car's AC smells musty, there's an easy fix If there is an odd, moldy smell that kicks in as soon as you turn your air conditioning on, you don't have to close your nose and bear it. More likely than not, you've built up some mold...
www.wikihow.com
(2nd)
MannymanX user fix below!!!!!
I think i found the solution!
A thicker filter with Activated Carbon!
https://www.amazon.com/gp/product/B07GY2MRZ9/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
It prevents from bacteria to grow on the filter, traps any bacteria particles and kills them before getting to the evap system.
I think the main issue with the OEM filter is that it lets too much air to flow and the HVAC system need to compensate for it by working extra hard to cool this air, that's why the evaporator has mold growing on it and it smells funky. This filter restrict some of the flow so it's not blowing as hard but it's more than enough.
I'm doing both b4 the problem gets worse, this should fix the smell as long as the condensate drain is clear from any mold, debris. These two items that Mikeru82 and MannymanX should fix this hopefully.
Disenfect the system with Lysol and buy a better filter, this is what I'm going to do and report back with results.
